Originally posted by sergysergy +10 is going to correct for 'extreme' backfocus with all your lenses. It is where you want it if your camera is backfocusing. If not it should be at 0.
Okay, I never use the back focus button. I have reset the adjustment back to zero. Is this what I want? I will set up a focus target and see if that helps.
Thnx a million for the info.
Tony
---------- Post added 07-21-22 at 11:52 PM ----------
Originally posted by StiffLegged Let’s try this t’other way round!
AF adjustment is for adjusting the AF when it’s not doing an accurate job and it can be set by different amounts for different lenses if necessary.
I use a K7 too: my kit 18-55 needs a small adjustment, my FA 80-320 needs a large adjustment and the A 35-105 and 28 prime need none at all. I’ve just bought a wideangle zoom and will be checking it this weekend to see if any AF adjustment is needed for it.
But simply applying +10 to all lenses without a good reason (you didn’t mention any) seems odd. You wouldn’t set your car’s steering to constantly turn left, would you?
I suppose I should have explained that I purchased the k-7 used and that was the setting it was on. There was no explanation anywhere as to what the purpose was for the
Auto-Focus Fine Tune Adjustment Feature. I will be setting up a focus target in the very near future and see how it goes. I am, admittedly unclear as to how to determine
a focus area is too far out front or too close in. Simply put, I really miss the days of film.
Thanks for all the help. I would appreciate how you determine you need to make
a large adjustment, especially with the 80~320 Mil.
Tony
