Originally posted by Ramps Ah you're right. Under it is 4 screws holding the entire "lever and button unit" in.
I guess that means the timber veneer skin is out the door as I don't think I'll be able to sneak that in under the lever.
Many thanks
Ramps
If you use a wood species with strong horizontal grain, like zebrawood, you could drill the hole, cut out a small piece on the side with a knife, slide the veneer around the timer post then glue the small piece back in. The grain hides the glue joint and no one will notice.
