Originally posted by rogerstg
I've found the opposite to be true. 5 cameras in 15 years and two Pentax batteries have bulged while none of the aftermarket have done the same. I buy Wasabi and DSTE.
Bulging happens with the D-LI109 versions and ... it happens if quickcharged.
The orig. D-BC109 isn't a quick-charger but charges gentle.
It measures temperature because only the orig. D-LI109 battery has the temperature-sensor inside, a 10kOhm@20°C NTC.
So if you bring an orig. D-LI109 to bulge (they bulge much easier than the D-LI90 because they use flat cells vs. round cells in the D-LI90!)
it is because it is overheated and the temperature-sensor is not in action because the clone-chargers don't measure temperature.
I have had lets say 150 Pentax DSLR using the D-LI109 on my workbench or in my hands:
From those ONLY and EXCLUSIVLY clone batteries had been in "bulge-mode"!
They also can bulge when slow-charged... again, because they lack the NTC sensor but a dummy sensor which is nothing else than a 10k resistor making the charger believe there would be temperature sensor. Without this dummy-sensor the orig. D-BC109 charger wouldn't charge a clone-battery!
I have brought all this up in
post #17.
That applies also to the Wasabi and DSLT clones! Both lack the T-sensor and their chargers have only 2 contacts, i.e. aren't
able to measure temperature with the OEM battery!
Normally when members here in the forum experience something going wrong with their Pentax items they write about it, did you?
I am not questioning your experience, just question why it happens.
The only time I recall that an orig. D-LI109 went wrong was
HERE
The reason this D-LI109 went wrong wasn't due to bulging but it wasn't properly assembled.
I see you wrote a review about the Wasabi D-LI90 clone:
You are wrong:
Neither Wasabi-batteries nor Wasabi-chargers are UL certified!
