Originally posted by Naj90 As I'm quite new to photography (like 1 week now), I actually want to try out everything. I like to have (interesting) people in my pictures, but with a nice background - if you know what I mean. Imagine the Champs Elysees in Paris as a background.
I'm with you.
I think that, for the type of photography that you are mentioning, you don't really want wide angle lenses because they make the scene in the background too small. You also don't really want a longer telephoto like that 75-300mm because it will focus on your subject and blur the background away.
What you want - in my opinion - is to walk around with a prime that is somewhat close to what we call the "normal range". In APS-C terms, I would say that would include lenses in the 24 to 50mm range. The 24mm would include more of the background without making it look excessively small. The 50mm will compress the background a bit (making it slightly larger than it is) without blurring it away (unless you shoot close to wide open). My suggestion would be the DA 35mm f/2.8 Limited Macro - the combination of that lens and the K10D is, in my opinion, pure magic. A much more affordable yet still very high quality alternative is the DA 35mm f/2.4 AL - very sharp, nice colors and - in my opinion - even better with skin tones than the Limited lens is. On the plus side it's also extremely light so even the K10D won't feel like a heavy camera.
Here's some suggestions, including those I just mentioned:
SMC Pentax DA 35mm f/2.8 Limited Macro - 200 to 300 used for the SMC version, the HD might be a bit more
SMC Pentax DA 35mm f/2.4 AL - about 80 dollars used
SMC Pentax DA 40mm f/2.8 Limited - about 150-200 dollars used. I haven't had it but lots of people like it a lot. There's a cheaper and even smaller XS version of this lens that can be had for 100-150 dollars used.
SMC Pentax-A 28mm f/2.8 - about 100 dollars used (or get the AF version SMC-Pentax-F 28mm f/2.8 for 125-200 dollars)
SIgma Ultrawide II - there's two versions, manual focus and AF. There's an AF copy in our Marketplace right not for about 80 dollars, which is a superb price for this wonderful lens.
SMC Petnax-F 50mm f/1.7 or SMC Pentax DA 50mm f/1.8 - for about 60-90 dollars used, lots of fun to be had with these AF lenses. Or, get the super-cheap yet at least as good, SMC Pentax-M 50mm f/1.7 for about 30 dollars used.
SMC Pentax FA 50mm f/1.4 - can't leave this one out as you can find them for about 100 dollars these days...
There's also some good 24mm f/2.8, 28mm f/2.8 and 35mm f/2.8 manual focus third party lenses that are cheap and fun to play with.
Good luck and let us know what you end up with.
