Originally posted by dlhawes it occurred to me this morning that the difference is that, given two lenses of identical focal length, the apsc lens is going to concentrate the same light in a narrower focus
I am not sure what you mean by "narrower focus". Each pixel on the sensor is getting the same amount of light whether you use a FF lens or aps-c lens, assuming both are the same FL and f-stop (ignoring potential vignetting at the edges/corners).
Originally posted by dlhawes while the ff lens is going to disperse the same light in a more diffuse pattern, resulting in a loss of analog resolution.
Nope. Each pixel is getting the same light as above. Assuming the two lenses (FF and aps-c) have identical resolving abilities, the resulting images will be identical.
On my K-1 I use FF lenses. If I put my K-1 into aps-c mode I get a narrower FOV image from the camera. I am using a smaller "bite" out of the image circle than the lens produces. How can switching the camera to aps-c mode affect the amount of light each central pixel receives or the resolving ability of the lens ?
