Originally posted by STUMPOFWAR I am in the process of looking for a donor k1000 to cannibalize the part. I've read on these forums, and other places, that the late model made in China versions have a different prism. I also read that the you can tell the difference between the China and other versions was that the China versions don't have "Asahi" on the front (besides the bottom plate). Thus my question...
I saw a for parts Hong Kong model without Asahi on the front up for auction. Does that have the same prism as the MIC or am I limited just to MIC models?
As far as I know a K1000 has never used a pentamirror, but instead a pentaprism. I have several, mostly older made in Japan and Hong Kong versions, with a couple Chinese-made bodies.
You are correct. The easiest way to tell the difference is the Asahi stamp in the front of the top cover prism housing. The later made in China models had plastic top and bottom covers. And yes, the Chinese versions are the ones prone to desilvering. I have a Chinese-made one with a perfect pentaprism, and one which has desilvering.
I tried to replace the defective prism with another from an older K1000 which was a little beat-up and they weren't exactly the same size. The older prism fit in the space, but it didn't give a clear viewfinder. I probably could have spent some time with shims, but the older prism was a little larger so it didn't have much room for adjustments. I ended up putting the old prism back in and living with the desilvering. Others have successfully switched out the prisms though. If you decide to try it, I used this video as a reference:
