I am thinking a Tokina 28mm is not a bad guess considering how common they are.
It appears to have a uv filter in place. That often protects the lens that is stored in a less than desirable spot but can also trap and enhance exist fungus problems. Many times you can pick up a horrid looking lens, remove the filter and there is a pristine lens under there
If you enjoy the thrill of the hunt then go for it. Ignore these doomsayers.
The trick is if it was a great catch come back and tell us - otherwise stay quiet
A final note - the existence of a PK lenscap doesn't mean it is necessarily K mount.
