Originally posted by Arisenfromash Dear all,
I really dislike that I've so far found no program that can edit my pentax raw files without saving it to a duplicate jpeg or proprietary format, sometimes with the bitrate mangled.
If someone could recommend a program preferably on a budget that'd be great.
Thanks!
You can do a lot worse than use the Pentax-supplied Digital Camera Utility
There are a couple of hoops to jump through when installing it from
Software Downloads : Support & Service | RICOH IMAGING but it'll work perfectly with files from your
*ist DS … I use it with mine, and all my other Pentax cameras
Basically, the download needs to be installed from a "disc" labelled S-SW177, so you can temporarily re-name your hard disc and install from the desktop (assuming Windows here) or copy the downloaded executable to a USB drive or even SD card that has been re-labelled appropriately and run from there.
The user interface is a little "different" and the program is a little quirky or cryptic in places, but it does the job, and it knows all about your camera and any Pentax a/f lenses you use on it
SATOBI with your *
ist DS images … click click done
More expensive options are available
