I'm trying to disable on DFS (dark frame substraction) on exposures longer than 30s and been following a guide, but I simply can't figure out why it doesn't work. Here's what I tried:
- Copy MODSET.474 file to SD card root
- Copy SYSPARAM.txt file to SD card with [DISABLENR] and when that didn't work, I tried [DISABLE_BULB_ALG]
I could successfully enable, and get into the debug mode, but DFS still ran. (40s exposure took around 80s)
I then downgraded the firmware to the very first version, 1.01 tried the same things again, but it still didn't work.
