Originally posted by Des The DA16-45/4 is way superior to the DA18-135 in it's range and gives the benefit of UWW down to 16mm, so almost a free DA15ltd.
Combined with a SMC F70-210 which has further reach and surpassed the DA18-135 in its range as well a cheap and superior combination
There is nothing wrong with used lenses if one knows how to check. I know that the DA18-135 is loved by many and it is quiet with its DC motor. But I would never waste a though of prefering to for the mentioned lenses. As said, the DA16-45 is almost DA20-40 limited quality. And if I would have to live with just one of those two, I think I'd go for the option having 16mm's because for landscape the difference between even 18 to 16mm is huge:
But of course if possible combined with a DA55-300PLM one has a fantastic combination!
Then one just graps the DA50/1,8 or... even better, the F50/1,7 and that tiny missing gap of 50mm is served with a fast prime.
Or the fantastic SMC A50/2,8 macro! Super light, great macro and good to learn manual focus.
Most people remember this lens only from old days during *ist-D times, maybe the K10D or K20D but haven't tried with a K-70, KP or even K3III.
It is also wrong to guess that many would have wobbly barrels by now!
This lens always had a slightly wobbly barrel due to it's construction. This had no effect on quality but:
Because the barrel extents when UWW some users weren't careful with it and sometimes hit the branch of a tree or whatever.
Then, and only then the wobble got stronger and decentering was the case.
This is because this lens has a unique technology implied, it is the only Pentax zoom-lens with working with the legendary Zeiss "floating elements"!
This technique you only find in used for the limiteds and the legendary (Hollywood) SMC Pentax K28/2!
This principle is easy to adjust with non-AF lenses such as Zeiss builds still today.
Adjusting/alining it in an AF-Zoom need a lot of precision work and knowledge!
I have often recommended this lens, many friends and family members own it. And only once did I come across a decentered lens, very easy to
find out when taking photos at 16mm's! So one makes sure one has the possibility of return or buys from a dealer.
So imo knowledge about this lens often is based on "hearsay" or from old times which won't count anymore because one hasn't tested this lens with a K70 or KP or K3III. So such information in most cases has zero connection with actual experience because it was built only up to 2014. It was stopped because it was too expensive! Similar to the legendary K28/2 and the Takumar 50/1,4 8-Element.
