Originally posted by Not a Number My understanding the OP doesn't want to reset to 0001 but start over from 1255. So if xxx_1255 is the highest number file found on the cards after clearing the file number memory the next file saved should be xxx_1256.
Yes.
Originally posted by Not a Number I think if you go into the memory settings and disable file number it will start numbering from what ever the highest number is found on any of the cards. You should turn the camera off to clear the number memory after you change the memory setting.
Some version of this worked - i.e. I reset variously the file number and folder number, and actually did a camera reset, too - while I had a card in the camera with the highest (desired!) file number.
Other than loosing a couple of custom white balances in the reset, all is now fine.
THANK YOU, Not a Number! and the others that made suggestions.
---------- Post added 10-08-22 at 11:54 AM ----------
Originally posted by UncleVanya Seems simple. Rest then add a card with the last legit file name and shoot another shot and all will be back to normal. Or just put a 9999 file in and shoot one and then a card with 1255 would follow and the next would be 1256.
I think you mean "reset" not "rest" - but yes, that (a reset) seems to work, as indicated in my response to Not a Number as well.
