Originally posted by mikesbike I have not measured, and just my impression, but my much newer K-1 II with its new battery, or an older substitute, seems to run low quicker than does my K-5 IIs with a contemporary older battery. I've just taken for granted, the larger, more complex camera taking a bit more juice, but it still goes a good length before needing a battery change- far longer than the KP or K-S2 cameras using the smaller D-Li109 type of battery. No complaints from me about this. I view both concepts in a positive way, each having advantages.
I definitely do not have the problems described by the OP. Should be interesting to see what the resolution turns out to be.
AFIK the K1 II is little changed to the K1-1 although some physical hardware differences as you have to return your -1 body to Pentax if you want to upgrade - so more than just firmware.
Pundits suggested the K1-1 was better at some tasks than other so after some consideration of what I really wanted to achieve with a modern FF went for this (at much reduced cost as well compared to the II)) and until now not disappointed.
V.old K5 batteries now showing 8.25v after a day on the new charger as opposed to ~7.2v after several days on the old one and indicating 100% in the K1 body, so old battery chemistry and maybe not so great old charger????? New battery still "on it's way" so hope to nail this soon. Good to take the K1 out yesterday for 30 odd frames on a quick walk and battery still OK, so all improving now. Not noticed a big difference with in-camera self discharge between the K1-1 and the old K5 , but not really thought about it before. So long as I can leave a week or two and still not see a drop from a nominal 100% all quite good enough for my usage.
