Originally posted by DeadJohn Your problem might be as simple as one bad button that is partly stuck and activating randomly. I think the "Disp" button would cause most of the problems you mentioned, but other buttons could cause it and there's still the chance of multiple controls having problems at the same time.
Electrical contact spray cleaner might help you. Carefully spray it into the camera around the buttons. Don't use too much.
Some buttons on my GR (model i, not ii) became overly sensitive after my camera got wet. I waited several days for it to dry but merely moving the camera could trigger random button presses. My problem improved over time, I guess continued use of buttons scraped off whatever residue was left behind by the water.
Contact-Spray is a very risky solution. It can help but it can do damage beyond repair.
I never had a GR in my hands so I don't know how to disassemble it but I had many Pentax DSRL with contact problems of the buttons.
Those which are not WR more so but often the On/Off Release-button of the K5-series.
In 95% of all cases it is dirt .... often sweat ... and at times particular sweat can lead to corrosion of contacts.
I have found terrible dirt problems on the buttons on the back side, which is similar to when you open a remote control and clean it.
(again here in most cases sweat).
See:
https://jamiecollinson.com/blog/disassembling-ricoh-gr-for-sensor-cleaning/
So I would disassemble and clean with pure alcool.
Nothing else.
