Originally posted by LyleC I have a K-5 whose exposure compensation button and on/off button which are sticking. Is there a lubricant (graphite) I can try to fix this? Do I have to go to a repair center?
Graphite is conductive … not what you want to be introducing into an electrical environment!
When you write "sticking", do you mean physically stiff to depress and return, as though some sugary substance may have been spilt on it, or intermittent contact?
If the former, with a "weather-sealed" camera like the K-5, careful application of some soapy water, with the camera held upside down so the water doesn't flow into the body, maybe sufficient.
If you've got intermittent electrical contact, with a "sealed" body, application of any cleaning substance shouldn't reach the contacts, so you'll need a partial disassembly to either reach the contacts to clean them or replace the switch assembly.
Good luck
