Originally posted by AnotherVoice Here I am at Rocky Mountain National Park, armed w/ my K-3iii, 300mm f4, and the 1.4 TC, chasing through the terrain looking for a moose. 30 min or so in the cold/wind and it quits autofocusing. I pull the TC. No change. Live view works but very slowly. Swap lenses and the camera works fine. Later, back in the cabin - no change. I put the lens on the K-1ii and it works like a champ. Any suggestions to get it working on the K-3iii again?
Well on the surface you have a power issue that the cold is bringing out. What were the temps? Did you try cleaning contacts on both with alcohol somewhere warm? Did the state of charge go down drastically as the cold hit the insides after a tiime? (W/o my battery grip w/ the big Pentax battery like the K-3iii uses on, I really notice the state of charge draining away very fast below about -6C with my KP and it is then useless after a few shots w/o replacing the battery with a warm one from an inside pocket which itself will need swapping after a short while. The battery grip, though obviates this well for my purposes.)
