01-03-2023, 04:45 PM   #1
K1000 Metering Issue at 1/2s?
Hi,
Both my son and I are using K1000's and we are both having the same issue where once we put the shutter speed to 1/2s, the needle jumps to the top. It's not just a small step that you would see moving from one stop to the next.
We could be at the bottom of the meter at 1/4s.. and once we move the shutter speed to 1/2s... the needle jumps to the top. It does not move down if we point to a darker/shaded area.
Is this a common thing? Both cameras have just had a CLA.
01-03-2023, 06:45 PM   #2
That doesn't sound right to me. If both cameras were serviced by the same person, I'd say it is probable that the technician made an identical error with each camera.
01-03-2023, 09:15 PM - 2 Likes   #3
Ole
Ole's Avatar
I think that your cameras are ok.
Depending on the speed of the film and the fastest F-stop of your lens (e.g. F1.4), you may experience that 1/2 sec is outside the meter's range.
The meter's range is 3 to 18 EV.
With an ISO (ASA) 100 film, 1/4 sec and F1.4 represents 3 EV, i.e. the lower limit of the meter.
At ISO 100 the meter range is illustrated with the "A" area, whereas "B" is outside range.
01-03-2023, 10:58 PM   #4
Pioneer's Avatar
This is interesting. I think I'll explore this a bit more but it would seem that Ole is right. Once you are outside of your meter's effective range it just defaults to a fail mode.
01-04-2023, 11:50 AM   #5
Interesting. We were both shooting 400, and this is happening even at f/22.
The same thing happens with 1/2s and 1s if I change the speed to 200.
01-04-2023, 02:01 PM - 1 Like   #6
Ole
Ole's Avatar
QuoteOriginally posted by TATJ Quote
It is the max. aperture of the lens that matters (e.g. F1.4), since the light is measured at fully open aperture.
At ISO 200 the meter's lower range (EV 3) would be 1/8 sec with an F1.4 lens.
01-04-2023, 09:24 PM - 1 Like   #7
grog85361's Avatar
Your camera is behaving normally. Ole has it right, the meter is out of it's usable range. Here is a chart from the SP500 manual, showing the usable range of the meter. The K1000 meter should be the same.
01-05-2023, 09:15 AM   #8
kayakfari's Avatar
These cameras use an old school Cds light meter that's not particularly suited to low light readings.
The later cams moved on to Silicon and Gallium meters which were much more sensitive, i.e. ME series, LX..
01-05-2023, 05:38 PM   #9
Thank you everyone for your help, especially to Ole and Grog! ��
01-05-2023, 06:33 PM   #10
Ole
Ole's Avatar
You're welcome, only glad to help!
camera, issue, jumps, k1000 metering issue, move, needle, pentax help, photography, shutter, top, troubleshooting
K-3 III bug in 2s self timer mode - Source of fuzzyness Pål Jensen Pentax K-3 III 146 12-07-2021 01:29 PM
Mirror lockup vs 2s Timer? lithedreamer Troubleshooting and Beginner Help 8 11-04-2016 09:15 AM
K-2S as K30 successor JXL Pentax K-S1 & K-S2 7 06-16-2016 11:54 AM
k3 or K5 2s for HDR? Timacn Pentax DSLR Discussion 7 05-19-2014 08:07 PM
Ricoh XR-2s discussion thread Lowell Goudge Pentax Compact Cameras 11 01-21-2013 10:08 AM
All times are GMT -7. The time now is 02:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
