Originally posted by pschlute
My first question is why f2.0?
When do you turn off AF ?
Why switch off LV? Why not just take the photo ?
Why f2.0? Coz, I was getting bored at f11 and I knew f2 would be a challenge and I just wanted to try and see thigs differently. In the woods, identifying an obvious subject and a supporting cast will be a new mindset, rather than the all-in-focus typically of landscapes. And also, why not ?
Why turn of AF? Fair point, Peter. Partly habit. Partly also, as battery preservation as I will then tend to adjust the exposure compensation/ aperture etc, and I can see the options more clearly with LV off. Then I will wander off for another shot without forgetting LV is on. Habit, does have a lot to do with it.
---------- Post added 01-08-23 at 08:52 AM ----------
Originally posted by UncleVanya
Shutter shock? What speed? Can you do an electronic shutter shot? No mup required.
I did think that as I've had problems with shutter shock and the 43 before. However, it does not correlate with the problematic shutter speeds.
Guess I could look at electronic shutter ...
---------- Post added 01-08-23 at 08:56 AM ----------
Originally posted by photoptimist
Crazy idea: is it possible that the vibrations caused by exiting LV (causing the mirror to drop) and then going into MUP (causing the mirror to flip back up) are slightly perturbing the focus? Unlike the heavily damped helicoids of older MF lenses, modern AF lenses tend to have light-weight focusing mechanisms.
To test this, might try doing your critical focus process in LV as usually, switch off LV (causing the mirror to drop), turn it back on (causing the mirror to flip back up), and see if the focus or subject has shifted in the least. You can repeatedly cycle from LV-on to LV-off to LV-on to see if the vibration sometimes bumps the focus a bit.
Good luck!
That's along the lines I was pondering, but couldn't think why it might be. Many thanks for suggestion. I will definitely experiment as you suggest.
---------- Post added 01-08-23 at 09:03 AM ----------
Originally posted by biz-engineer
That's normal because LV focusing doesn't necessarily focus with the lens diaphragm wide open, depending on available light and also if you zoom in or not and also if you do a DoF preview of not, and if the lens itself has some amount of focus shift vs aperture. Best is to focus in LV at 100% with DoF preview (lens stopped down).
Also:
- MUP is not necessary in LV because mirror is already up, you don't need to go back to OVF after focusing in LV @ 100%
- Just focus in LV 100% with your hoodman loupe, DoF preview, take the shot, and get the perfectly focused, award winning, pixel peeping approved picture
Thank you. See my reply to Peter about switching back to OVF. Habit and probably a poor one. I can see a compromise/experiment coming. Take the first shot in LV, then switch off LV and fiddle with exposure settings, as above.
Award winning
I think this will be 100% unlikely at f2 with my inclination for the mundane
