Originally posted by Sandy Hancock That's pretty bad! Were you using the hood? Any filter?
I haven't seen anything like this with mine, but I'm not sure I have shot it with the sun in the frame yet. It might be time to do some tests....
I was using the hood, and a protector filter. I've done some quick tests, and while the filter makes things slightly worse, this veiling flare is still very apparent. The flare still happens (to a lesser extent) when there's a bright background but no sun.
---------- Post added 01-13-23 at 07:55 AM ----------
Originally posted by luftfluss Well, according to the
PF review of the lens, the flare suppression in the reviewer's copy was "not particularly impressive".
Yes, I've seen it. But that review statement is so vague I can't tell if my copy of the lens is typical.
Looking into the lens from both ends, all seems as it should be. In use, focusing and sharpness are just as I had hoped.
