Originally posted by pentasonic49
Try that with a manual zoom, you have to have a guess at what focal lenght to put in, I would go for the longest.
That may be the worst option.
Pictures taken using the mid or lower FL range will be over-compensated by the SR mechanism if you enter a longer FL setting in the SR menu.. Best advice is to use either the actual FL, or failing that, the lowest FL or the mid range with a bias toward the lower.
Registering a lower FL than the one in use may lead to a less than ideal SR response, but it wont induce shake. Registering a longer FL can do just that
