Originally posted by Not a Number What body are you using?
When the lenses are not attached can they be switched easily in and out of the "A" setting?
Thanks for your questions.
Yes, easily in and out. Both lenses (35mm and the 45-85mm) easily switch back and forth between "A" and any of the manual aperture numbers f/22 or f/32 to f/5.6. This is true whether the lens is mounted or not.
When either lens is attached, it is attached to either a Fotodiox TLT ROKR adapter or a Fotodiox RhinoCam Vertex adapter---for shifting and possibly tilt---to Sony E-mount. My third adapter from Photodiox is arriving tomorrow (for Graflex 4x5). I will check the lenses on this third adapter too. But I don't yet have a Pentax 645 camera to test my lenses on.
For all three Photodiox adapters (Pentax 645 lens to Sony E camera), I have no use for the "A" setting.
---------- Post added 01-17-23 at 02:57 PM ----------
Originally posted by Just1MoreDave I have an idea about this but disclaimer: I have no experience with the 645 lenses or cameras.
The 45-85 zoom is a constant aperture zoom. These lenses can appear to be slightly stopped down at the wide angle end of the zoom. The aperture blades may be visible when you look through the front of the lens, when the aperture ring is at f4.5. That is completely normal.
I only have a few constant aperture zooms and the only lens that does this is my DA 16-45mm f4. At the 16mm end and wide open, you can see the aperture blades from the front. They aren't in the image frame, though. I believe I first heard about the phenomenon when people were looking at the DA*16-50mm f2.8, wondering if it was really f2.8.
Bingo! Thanks! I had no idea this behavior of a zoom wide open was possible. Yes, on the zoom, the blades are visible even wide open at the wider focal lengths, and not visible at the more telephoto focal lengths. Exactly as you guessed!
It appears that the best way for me to avoid the excessive pressure on the lens aperture ring that I find needed to get to wide open is to use the lenses a lot more for a while, but more importantly, to set the aperture to the widest manual setting just before mounting the lens.
I will be testing this more later tonight, and I may have some follow-up question tomorrow or later this week. It is close to no problem now, perhaps in part because I've been doing so much checking and loosening things up. And also understanding that the zoom behavior often or usually shows the octagon even wide open.
