The camera is moving the lever correctly with only the lens attached. Even using the smallest tube with the lens and camera and it does not move the lever. Strange. I think it has nothing to do with the contacts. The Old lens has also no contacts. And that works oke on te camera alone.
---------- Post added 01-19-2023 at 09:29 PM ----------
Originally posted by Argos Maybe your extension tubes have a black anodized rear in stead of a blank metal rear. If that is the case, the camera does not detect the lens.
. I tested and looked at the 2 ring. The previous owner made the tube a bit blank. But as I moved the tube a bit, it suddenly worked !! So my first action next week is to blank al 3 tubes thoroughly. Thanks for the hint. I did not realize that the shortening of the pins is necessary for getting good results. Hoe did it work in the old analog time? The Old camera body s did not have those contacts I presume?
---------- Post added 01-19-2023 at 09:30 PM ----------
. I tested and looked at the 2 ring. The previous owner made the tube a bit blank. But as I moved the tube a bit, it suddenly worked !! So my first action next week is to blank al 3 tubes thoroughly. Thanks for the hint. I did not realize that the shortening of the pins is necessary for getting good results. Hoe did it work in the old analog time? The Old camera body s did not have those contacts I presume? Thanks for your answer.
