01-21-2023, 10:09 PM   #1
Gerbermiester's Avatar
D-FA* 50mm f/1.4 sticky blades? Anyone seen this before?
Hi folks.
I just got a used Pentax-D Fa* 50mm f/1.4 from KEH for an absolute steal.
However, after using it to shoot a family dinner tonight, I noticed some pretty erratic exposures when reviewing the images on my K-1 (running firmware 2.10, the latest). From one image to the next, the exposure was hopping all over the place. Given that I was shooting in manual mode and in continuous drive mode (NOT bracketing), this was odd. The exposure ought to have been identical from frame to frame, since the camera's settings and the scene I was shooting weren't changing between shots. One image would be over exposed and the next would be under exposed, and the next after that would be right on the money or, just as likely, two stops too dark.
When I got back home I began running a few tests and took this video of the issue as it happened.
It looks like the aperture is sticking, but there is not evidence of oil (or anything else) on the blades. The strangest bit of all is that when the aperture gets stuck in the stopped down position, it can be reset by cycling the power switch on the camera body.
This made me start wondering that perhaps this stuck aperture was a firmware issue rather than a sticky blade issue. To test this theory, I repeated my tests on my only other KAF4 lens, a D-FA 70-210mm; but, the 70-210mm stops down and opens up again just peachy-keen.
If you have had any experience with this, please let me know! I'm thinking that I'll be sending this lens back to KEH for a refund. I would love to keep it if I could get it working properly, it absolutely SLAPS!
Am I missing something obvious, or is this 50mm lens defective?
01-22-2023, 01:20 AM - 1 Like   #2
Not a Number's Avatar
I would just return the lens. There is most likely an electrical fault either in the connections or the diaphragm actuator. The cost of repair and what you paid for the lens is likely to exceed what the lens new would cost.
01-22-2023, 04:28 AM - 1 Like   #3
Kevin B123's Avatar
I agree with Not a Number.
It is defective and not worth your time as it might become unreliable again if you can clear the fault.
01-22-2023, 07:38 AM   #4
pschlute's Avatar
QuoteOriginally posted by Gerbermiester Quote
I presume the fault was not mentioned prior to purchase ?
01-22-2023, 08:55 AM   #5
Mikesul's Avatar
Doesn't KEH still include a 6 month warranty?
01-22-2023, 10:03 AM - 1 Like   #6
sergysergy's Avatar
Maybe unrelated and probably a faulty lens but it looks like the battery was very low. I don't know if that may have an impact on the lens performance.
01-22-2023, 10:51 AM - 1 Like   #7
I'd take them on on their warranty.
They have to solve it.
01-22-2023, 03:18 PM   #8
Thanks everyone. That seems like the best way forward. Sometimes it's just nice to have a sanity check!
That is correct. No mention was made.
01-22-2023, 03:38 PM   #9
pschlute's Avatar
Send it back. No question.
01-22-2023, 06:46 PM   #10
Paul the Sunman's Avatar
It is troubling to hear this story. I had redefined the word "perfection" in terms of this lens.
01-23-2023, 08:19 PM   #11
Who buying used, one never knows what that particular item might have been through- usually only the previous owner. Luckily, KEH is a very fair and reputable outfit, from what I have seen, so you should be able to make the return without any problem.
01-29-2023, 09:21 AM   #12
Mikesul's Avatar
Let us know how it works out. Since it is under warranty they should be able to return a fully functional lens to you. The DFA 50 1.4 is worth a little hassle.
01-29-2023, 09:48 AM - 1 Like   #13
Wheatfield's Avatar
QuoteOriginally posted by Paul the Sunman Quote
My copy is being held together with electrical tape.....
01-29-2023, 10:02 AM   #14
pschlute's Avatar
I have owned this lens from when it first came out without issue. It is a shame the OP has issues with his, but as has been pointed out, who knows what stresses a second hand lens has been through before purchase.
If there was a general problem with this lens I think we may have seen more than one post on the issue.
50mm, 70-210mm, aperture, blades, camera, frame, issue, lens, mode, pentax help, photography, tests, troubleshooting
Pentacon 135mm F2.8 ~ 15 blades = BOKEH MONSTER ~ 6 blades = NOT ? minahasa Pentax SLR Lens Discussion 5 04-03-2021 05:35 PM
K-1 bricked, anyone seen this happen before? blackcloudbrew Pentax Full Frame 25 12-15-2019 09:46 AM
Weird effect in images on K-3... anyone seen this before? BigMackCam Pentax DSLR Discussion 12 07-10-2016 06:32 AM
A Pentax I've Seen Seen Or Heard Of Before/ shutterpuppy Film SLRs and Compact Film Cameras 9 02-03-2009 12:32 PM
All times are GMT -7. The time now is 01:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
