Originally posted by photoptimist It can be caused by using the electronic shutter with many kinds of artificial lighting.
That's almost surely it.
Originally posted by Digitalis Solid state LED lighting strikes again. Typically you need to use a longer shutter speeds (1/60th or slower) to diminish the flutter from PWM driven lights.
For proper exposure yes. You show 1/250 sec - if this was mechanical shutter, you would be lucky to get anything - the LED lights may turn almost completely off and on at 60 or 50 Hz, depending on where you live. At such speeds, you have about a 50-50 chance of shooting when the lights are "on'!
I'd go even slower - 1/30 sec or less. Why ISO 2000? If you are trying to stop action (doesn't look particularly relevant here), you are in trouble either way - ES is no good (people move during the exposure), and as noted, the lights are going on and off.
