Originally posted by MDRatliffe It's a rare issue, but the last few times I've done astrophotography I've noticed a row along the bottom of my display that's just completely blank. I'm not sure if it's damage, or just the cold from leaving my camera out for a couple hours in Canadian winter, but it goes away the next morning after the camera's warmed up. Talking with a local camera repair to deal with aperture block failure, I mentioned this issue and they sent me a link to order a replacement display, and I just want to get some more opinions if that'd be overkill, or if the issue if likely to start getting worse.
LCD stands for liquid crystal display, these crystals are modified by electric currents to form characters.
And like any liquid, they are temperature sensitive.
It could be that the bottom section gets less current, making only a difference if colder. Could be cable, corrosion, aging driver...or the lcd itself. Or it chills more because bottom side is more exposed. The display is controlled in rows and columns arrangement, so it seems only a section of rows is affected, which could be linked to specific cables or driver ...hitting its limit of operation.
The new screen, does the specification states a temperature range?
Compare to your outdoor use, and take into account wind as extra cooling factor. I guess in astro your camera is on tripod and pretty much more exposed then when carried around.
A fold out screen probably cools down quicker....as more exposed to wind chill.
And an illuminated screen is tiny bit warmer...but in astro you might avoid that.
Note that pentax states explicitly for K-1 mII that it functions up to -10⁰C (only?) as a feature (achievement?, better than other models?), not sure where other models land...
High reliability | PENTAX K-1 Mark II | RICOH IMAGING
In the end it might just be the cold...the camera telling you it's time to shelter.
