Guys, hello !
I have bought a Samyang FF 20 mm f1.8 lens, marvellous for it's image quality, but i had immediatly the problem to unmount the lens after usage on a K-1 : the lens does not goes out.
I was in A mode on the aperture ring. I have discovered that the "Pentax" mount was a "KR" mount (Thanks the vendor)
Finally i achieved unmounting the lens putting the aperture so some aperture value instead of the A value. The pin retracts. But in this mode I obviously can't use the automatic exp. settings from the body.
Is it dangerous for the body mount keeping this PIN ?
Do I have to remove this PIN ?
If I do that, does the A mode continue to work without this PIN ?
I have some Sigma with aperture ring and A mode that do work in A mode absolutely properly without this pin.
I want to use the A mode.
... Or do I through away this lens and the money it costed ?
In fact I have many two other Samyang (35 and 80) not marked KR but with a (lower erectil (!!)) Ricoh Pin in A mode. They do not cause problem at remove ... because the pin is not so tall.
including two photos
have a good day. and thank you for your attention.
