02-08-2023, 08:15 AM   #1
Pentax k-1 won't tether pcp issue
Hi everyone,
I've had my k1 a little while and getting back in to shooting more and was wanting to shoot tethered for ease as I have a shoot tomorrow.
However, after getting a new tether tools cable, everything plugs in okay and then the camera is basically dead. It says PCP at the top and I basically can't even take a picture on the camera.
On Lightroom it can't find the camera to tether to, I've downloaded the correct plug in and tried different ports.
My pentax is version 1.5, when I checked this was still fine and should tether normally but its no good.
I'm now charging my battery before upgrading to the newest firmware but I'm not sure if its going to help.
If its any use i'm using the new Macbook pro M1 Max. Just wondering if anyone had similar problems? Seems to not be much info out there on this.
02-08-2023, 08:36 AM - 1 Like   #2
AfterPentax Mark II's Avatar
did you set the camera usb connection to PTP? wrench menu 2! That you cannot take a picture indicates that you probably have the wrong setting (MSC) because that is meant to make a connection whereby your camera becomes an external drive. See page 87 of the manual.
02-08-2023, 10:06 AM   #3
QuoteOriginally posted by AfterPentax Mark II Quote
Yes so it's on all the right settings PTP included, so really unsure what's going on with it!
02-08-2023, 10:39 AM   #4
...just plugging in my Tether Tools cable to LR (Windows) for tomorrow's shoot. Working fine. However, I do have a wonky USB card/socket connection that means I have to make 100% sure it is properly in place and doesn't wobble, if not I don't get a connection to LR. I've tied the USB cable tightly to the body of the camera with fishing line. Possible issue ?
02-08-2023, 10:40 AM   #5
I don't think Pentax cameras are supported for tethered shooting with Lightroom Classic and V6. The list of currently supported cameras only includes some Nikon and Canon models.
Edit - On checking the Tether Tools website I see you need to use the Ricoh supplied LR plugin, Adobe don't offer one.
02-08-2023, 11:46 AM   #6
QuoteOriginally posted by steephill Quote
Not sure I ever installed a plugin.
I've used several different USB cables, settling on the Tether Tool Active USB version. All worked fine, just the Active one was more reliable for a longer cable. I've used this setup over several different versions of LR for 3 years or so.
camera, k-1 won't tether, pentax, pentax help, pentax k-1, photography, shoot, tether, troubleshooting
Blast from the past - anyone tell me how to use debug mode in PK Tether? LittleSkink Troubleshooting and Beginner Help 8 01-22-2022 04:48 AM
Architecture I won, I won, I won Culture Post Your Photos! 12 11-13-2015 11:34 PM
For Sale - Sold: New in box: 16GB Pentax FLUcard O-FC1 (tether your K-3, K-3II, K-S1, or 645z) cheekygeek Sold Items 3 10-28-2015 05:08 AM
What do you use to tether your K3 to laptop? Do I have to spend 50 bucks on a Tether? CeciProAm Pentax K-3 & K-3 II 8 02-05-2015 05:19 PM
PK-Tether mcro focus adjustment issue AlessandroB Pentax K-5 & K-5 II 2 07-02-2012 10:53 AM
All times are GMT -7. The time now is 02:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
