Hi everyone,
I recently purchased a K10D, but seems to be having issues with the battery/charger.
It came with one original battery and one Wasabi, with a wasabi charger. The camera turns on with original one, and does not with the wasabi.
When the camera turns on, it stays on for maybe a minute (I was able to take a picture and confirm the shutter count), then displays battery depleted. When the battery is inserted, the battery indicator shows full battery, then drops to have, then empty during that time.
For the charger, when charging the light turns red, and when complete it turns green. I’m leaning towards the charger being the problem as with no battery connected the charger light is green. When either battery is connected, the light remains green. I let the wasabi battery sit on the charger overnight (light green entire time), and still nothing when trying it.
I think the camera set for awhile and now the internal battery is also depleted as it ask for the time to be set every time I change the battery.
I was able to check the firmware and it is still on V1.00.
Does this sound like a battery issue? Or possibly something with the camera itself and ask to return the camera? Any other troubleshooting ideas?
