Originally posted by Not a Number When it comes to cleaning contacts I try to avoid using anything abrasive. The contacts are usually clad in chrome or nickel alloys to resist oxidation and corrosion. Although the plating may be damaged by leakage corrosion why remove more. You can scrape most of it off with a plastic card, wooden stick (tongue depressor) or nylon pot and pan scraper. Most battery button cells chemistry is basic in nature so clean with a mild acid like vinegar. You can usually tell from the color of the leakage - white/blue/greenish is usually a base (alkaline). Yellow/orange/reddish is usually and acid so clean with baking soda. The appropriate cleaning agent will neutralize the acid or base and halt further corrosion. Just remember to clean up further with water.
Looking at it, it doesn't look corroded. There's onn leakage, nothing to wipe off. It really doesn't look like it needs to be cleaned. It just looks slightly pitted compared to the one from the MX that works. I'm surprised the one from the KX doesn't work. It looks like it should.
