Originally posted by Just1MoreDave Also clean the battery contacts. A pencil eraser is OK as long as you aren't a maniac scrubbing them. Electrical contact cleaner is more gentle. My *ist DS had the same shutter problem and that fixed it.
The batterycontacts of the K-r are different, identical to those of the K30, K50, K70 etc. and sit deep inside only.
They don't cause problems.
Very different to the contacts of the *ist-Series, K100D, K200D, K-m and K-x which often do cause problems.
Here a clean is not all but also the contacts on the battery-door need to be bend upwards.
The problem with the K-r usually is that flimsy On/Off-shutterrelease button, because as described in the first post, it can
"fire without doing anything". It is then usually is a contact problem
