Originally posted by UncleVanya This is true but a better way (perhaps) to phrase it is that the angle of view is the same as any 24mm used on whatever sensor the OP has.
Which I think is what you alluded to - the name “mini-wide” might imply wide angle use - but that only applies to cameras with a sensor that is as large as the 35mm film the lens was designed for. Use on a smaller sensor will crop away the parts that fall outside the sensor making it appear far narrower than “wide”.
Thanks for the clarification - that is exactly what I intended to say, but phrased it badly (and expected the improvements as soon as I wrote it !
What I would say, however, is that there is a possibility that purchasers of a 'wide angle' lens, and being unaware of the image cropping on smaller sensors, or that the description only applies to 35mm or FF sensors, may feel the lens has been mis-represented by the seller.
T
