3 Days Ago   #1
K3II UHS-II SD Cards
It's been a while, I'm wondering if there were any firmware updates that allows full speed use of UHS-II Cards in the K3II? Thanks
3 Days Ago - 1 Like   #2
Latest version is 1.12;
Latest PENTAX K-3? Firmware Update : Software Downloads | RICOH IMAGING. I also believe this would require different hardware for the card-reader
3 Days Ago - 1 Like   #3
KiloHotelphoto's Avatar
I don't think the K3 II is UHS II compatible.
3 Days Ago - 1 Like   #4
QuoteOriginally posted by KiloHotelphoto Quote
The manual says UHS1.
A faster bus transfer speed needs indeed new hardware, not something a sw update can do.
Sometimes they build already faster hardware into a device, but need sw update to activate it, typically when the final version of standard or protocol is not completed/approved. But in that case the device specs typically state the hardware as such (like UHS1, hw ready for UHS2) , after all it is a marketing argument....
Typically that’s only a short time window of opportunity, the hardware standard is only slightly earlier frozen than the sw standard....
But you can use UHS2 cards in the camera, they will only operate at UHS1 speeds as they are backward compatible.
You might benefit elsewhere of faster speeds, like when copying the cards into a (newer) pc or backup device.
2 Days Ago - 1 Like   #5
Fogel70's Avatar
I do not think K3 II even get max speed out of a UHS-I card. I have test of write speed of 35 MB/s from K3 II.
2 Days Ago   #6
QuoteOriginally posted by Fogel70 Quote
Any postprocessing slows down ( might range from raw+jpg creation, digital filters, lens correction, level correction....) ...where processor becomes bottle neck.
2 Days Ago   #7
Fogel70's Avatar
QuoteOriginally posted by mlag Quote
Yeah but when measuring write speed on cameras all processing are usually turned off.
Pentax K-3 II SD Card Write Speed Comparison of Fastest Memory Cards for the Pentax K3 II Digital Camera - Camera Memory Speed Comparison & Performance tests for SD and CF cards
2 Days Ago   #8
Exactly.
But K-3II is a versatile camera with many options and some are easily forgotten....
camera, cards, k3ii, k3ii uhs-i sd, pentax help, photography, troubleshooting
Any drawbacks to using UHS-II cards in a UHS-I slot? Qwntm Pentax DSLR Discussion 13 11-30-2020 06:52 AM
The K-1 ii deserved a faster write to SD card, UHS-II speeds are simply not accurate brainwave Pentax DSLR Discussion 25 07-20-2020 10:57 AM
SD cards and Micro SD cards seeking more Knowledge, facts and opinions aslyfox Troubleshooting and Beginner Help 13 09-14-2016 07:51 PM
Transcend 600X UHS-I SD Cards wtlwdwgn Pentax K-3 & K-3 II 4 03-31-2014 03:25 PM
UHS SD cards. Kona Troubleshooting and Beginner Help 2 11-02-2011 06:58 PM
All times are GMT -7. The time now is 02:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
