Originally posted by Kevin B123 You have probably set to cross process on the four way control pad, the right hand button. Easy done, I have the medal too.
Similar. I changed the white balance, and this part is good.
---------- Post added 04-02-23 at 07:46 PM ----------
Originally posted by c.a.m It's possible that the White Balance was set to an option that is not suitable for the lighting. Check the left button on the four-way controller, reset it to AWB -- Auto White Balance.
- Craig
I changed the white balance and it is back to normal.
