The screen "appears" dark i.e. as if you cannot see the take photo because the solenoid is stuck, that is why ABF is also called "dark image syndrome".
As I have explained in this test method:
How to detect aperture-block failure/stuck solenoid on Pentax K-70 - PentaxForums.com
often in LiveView-mode the Pentax "seems to work alright". This is because in LV mode the mirrow goes up, you see on the screen the "scene"
but metering is not correct because the solenoid doesn't move the aperture to f4,0 but remains stuck and thus your Pentax meters fully closed (f22 for example, depending on your lens).
The same applies for video-mode, the mirror goes up and you see the scene, metering is done with f22 or even higher depending on your lens.
The camera records at least for a while in LV and video-mode.
In all the tutorials etc I wrote I never mentioned video-mode because I never use it. So it never was in my "focus of attention"
