Hi all, first post.
I have a problem with reverse mounting my El-Nikkor 50mm onto my newly acquired Asahi Auto bellows (made approximately 1972, not sure, estate sale). The bellows has M42 at each end. The camera end I have adapted correctly.
I can use the M42 55mm Takumar lenses that came with the bellows, in forwards and reverse, as they screw on with no issue, but I want to convert the lens-end M42 to something else I can use, preferably Nikon F mount, or anything I can adapt from there.
In the attached picture I sketch out the two possibilities that come to mind, but perhaps there are other solutions you could suggest.
The lens end of the bellows has an M42 female bayonet.
The camera is a Fujifilm X mount that I adapt to Nikon F and go from there with a Nikon reverser ring then filter ring connections. This end of things is not an issue as far as I understand.
Option 1 is to get a M42 reversing ring that would connect its M42 male bayonet to the bellows and have a 49/52/55mm male filter at the outward pointing end. This would then allow the El-Nikkor to use step-up rings to attach it in reverse onto the reverser ring. This reverser ring is not very common in NZ and I'd have to order it from overseas. I am doing something like this already for a setup without bellows using an F mount reverser ring onto an adapted Fuji body, so the basic concept is sound.
Option 2 is to get a Nikon (outward side) to M42 (inward side) mount adaptor. This would let me repeat what I'm doing now with my F mount, but with bellows in-between. However a Nikon (out) to M42 (in) adaptor in this direction seems very rare as it can't be used for non-reversed lenses and practically nobody wants or makes them. They do exist though. There are lots of M42 lens to Nikon mount adaptors, but that's in the wrong direction. Does anyone know where to get one?
Does anybody have any suggestions as to alternatives, combinations of other adaptors that are more common, or any clarifications about how this works? I'm only interested in macro, so issues with infinity focus are not relevant.
The PDF manual I have found for the bellows says that when you reverse the front plate you get a 52mm filter thread on the outside that you can connect things to (such as my 52-52 reverser ring), but I think I must have an earlier version of the bellows where this was not present, there's just some small screw that can't really connect or hold a reversed lens.
Let me know if there's any more information you need, or photos.
If you're a mod and this is in the wrong forum please move it somewhere more appropriate.
