Originally posted by ramseybuckeye I don't have either of those two models, but find where you select the active autofocus area you should be able to change it, your K-3II must be set on spot, not sure about the K-1.
I have confirmed I have the active AF set to the small square (on the K3ii). I guess the difference is on the K3ii there are red squares flickering on and off (I assume confirming that is the AF point), whereas on the K1 the squares are black and tend to stay on all the time, instead of flickering (which I prefer). Is there some way to make it act in a similar way on the K3ii?
