Originally posted by StiffLegged Might be time to revisit the Dot Tune focus calibration, but is this true for all lenses or just one? And are you focusing through the viewfinder or using live view focus?
This is the first time I have noticed the issue with this lens. On occasion there have been issues with the SMC Takumar F 70~210mm lens, although this lens is known for
inconsistent Auto-Focus. Nothing wrong with it, just the way it is made. I will go ahead and upload the image I am referring to. I will include EXIF Data.
Thnx,
Tony
---------- Post added 04-22-23 at 10:18 AM ----------
Originally posted by UncleVanya Which lens?
Yes, please post the file.
When you say the focus indicator, I assume you mean the red dot? That only indicates where focus is being attempted. Was the green hexagon fully lighted and solid - not blinking?
In this instance, I am referring to the SMC Pentax-FA 28 ~ 80mm lens. It appears as though I misspoke regarding which light. I meant to refer to the In-Focus Hexagon,
Yellow Light which was in the solid position when shooting. I will go ahead and upload the image in a minute.
Thanks,
Tony
---------- Post added 04-22-23 at 10:19 AM ----------
Here is the image. As is readily visible, the in focus areas are all over the map. Everywhere except where I needed it.
Thanks very much.
Tony
