Originally posted by jk333 Can someone go through this... step by step... I have the K200...
This is what I'm getting from what I'm reading above...
So, put it to JPEG pictures. THEN I change it it to the Bracket mode. (rather than Hi-continuous) Then I hit FN, then left, scroll down to Shutter adjust and take the picture...
Then the picture that comes up is bracketed? Or are their options that I can choose from with the picture that comes up?
Partly right.: Set the drive mode to autobracket, use the wheel to select how far apart the exposure settings will be, hit ok, compose your shot, hold the shutter release untill all 3 shots have been taken, transfer to your pc and use your favorite photo editor to merge the HDR image.
The other part you mentioned(left, scroll down to Shutter, adjust and take picture...) is how you manualy set your white balance, and the resulting image is to confirm and make adjustments, but has nothing to do with HDR and shouldn't be fooled with unless you know what you're doing or just want to play around.
What's being discussed here is the cameras HDR filter and/or(more specificaly) D-Range setting. The first is applied in the playback menu after the image has been shot.
The other is in the ISO Menu and is found by pressing Function - Right - Function.
I haven't played with either of these on the K200, but can say with certainty that neither will yeild an "HDR" image. But, either or both might help to gain a little more detail from high contrast situations.
