Originally posted by ajaxmgr I just purchased a K20D. The last camera I purchased 20 years ago was a 35 mm Cannon. I am not understanding the manual and would like some help knowing how to set my shutter speeds for fast action shots. Thanks in advance for your help, and HAPPY NEW YEAR.
Use either manual or Tv (which stands for "time value) You then use a control wheel to set shutter speed.
If you are in manual, you will have to use the other control wheel to set aperture until the light meter indicates correct exposure, if you are in Tv, the camera will set the aperture.
You can also do this from the P setting by using the control wheels to bias the program line.
Note, you cannot do any of this from the green auto mode.
Im not going to go near what you need to do if you are using pre A series lenses, as you haven't indicated you are using one.
