Originally posted by morepower Manual states that function not available in Live View, but the only way to set the feature is in... Live View! Any help appreciated, thanks!
What do you mean "the only way to set the feature"?
When using ND filters I'm usually in M-Mode; I add exposure time according to the used filter strength to the initial exposure reading without the filter.
After I added the filter I check focus in LV with magnification, I turn off LV and take the picture with the help of MLU (when using back button focus nothing else is needed, otherwise you might have to switch the focus lever from AF to MF before taking the image to prevent the AF from messing up the image / I am not sure about that though as I often use manual focus lenses and I only use back button focusing)
