Very helpful, thanks.
I aim to make a start in a day or two. You peeled back the leatherette, that's a good clue. I was hoping the top or bottom 'plastic' plates would be freed up by removal of the screws we discussed. Obviously not quite that simple.
OK: All small screws around each side close to top plate removed, these are just underneath the leatherette. Single small screw removed next to tripod mount thread. The whole of the bottom section, consisting of the entire surround and base plate slides off. (As discovered, no need to remove single screw top centre of control switch panel, this holds a small printed circuit board in place).
Inside: at least two printed circuit boards, with very fine connecting wires. Presumed pulsing circuits for motors.
1st point of weakness: Gold plated, leaf spring actuated contacts, which feed power to motor drive; these are very delicate. One leaf spring seems not making good contact with gold plated pin.
TO BE CONTINUED..!
Reason: Updated with progress so far
