Originally posted by Aeglil
Btw BOWER 52mm UV is the name of the lens.
Unfortunately, you have uncovered another layer of interference - the Bower 52mm UV is in fact a filter still attached to the front of the lens. You will have to unscrew that, in the same fashion as removing the adapter, but being narrow it may be harder to grip.
If you could take a photo or several of the lens and camera from different angles with your phone and post those, it would help us tremendously to ascertain exactly which lens you have and proffer more pertinent advice.
