Originally posted by pschlute I
If it is the bayonet Takumar 135/2.5, make sure the camera is set to allow aperture ring as advised above, and that the aperture ring is set to the A position.
ps....I edited the title for you
Thank you for your response. Yes it is the bayonet 135/2.5 however it does not have an A on the aptitude ring and my setting is using aperture ring ON. Do you have further advice? It will be very much appreciated. Thank you.
---------- Post added 06-12-23 at 09:33 AM ----------
Originally posted by AfterPentax Mark II If you experience that with the Takumar Live View in K-1 II works, but not with the K-3 III, then something must be wrong with the K-3. Because whatever the settings, Live View works at all time. If you cannot take a picture it might be one of the settings to work with a manual lens. But then you should encounter the same problem when using the viewfinder. But the things are a bit complicated because you do not tell us exactly what is happening and when it is happening. As it is now I conclude that your K3- Mark III has a problem and needs servicing....
Thank you for this information. I can take a picture in live view with the k-3 however the live view screen is almost completely dark and just has a very very dim view even with the iSO increased to 52,000. I took a picture with the view finder 1/250, f2.8, ISO 100 and then switched to live view and took the same shot. Both came out the same quality. Just no view on the screen in live view mode. I guess I have to send it in for service. Also my lens is the bayonet model and has no A on the aperture ring. My camera is set to ON in the aperture menu setting
Originally posted by K2 to K50 Suggest edit title for spelling - Line vs Live: confusing to viewers.
Have you set Aperture Ring enabled to On on the K3 iii?
Yes it is on.
