You can check a sdcard also on pc’s with a sd card slot.
Some older cards had a r/w protect switch, if present, select write.... ( or unlock, might be brand dependent). Sometimes the switch is accidentally changed during insert/ remove. Read should always be possible...
If you try other cards , it supports SD, SDHC, SDXC uhs-1 types.... try (also) smaller cards like 16 gb , the newest like 256+ gb might be more problematic on older camera.
If none of your cards work, I would return camera....
Normally in camera format is advised, but sometimes first a format on pc can help, and reformat in camera.
