11-19-2023, 09:02 AM   #1
AF400FTZ Failure
I have just checked my old AF400FTZ and after fitting batteries and switching on, the charging light initially came on (I heard the charging sound) and then it went off and now will do nothing. Tried svereal sets of batteries to no avail. I also managed to attach an external 6V bench Power Supply (PSU), but still no luck (it draws about 70mA from the PSU) I assume a failure in the high voltage inverter or such?
Does anyone have a schematic diagram of this unit?
11-23-2023, 10:39 PM   #2
Alex645's Avatar
QuoteOriginally posted by nigelpritchard Quote
Sorry, I don't have a schematic for the AF400FTZ. It sounds like the thyristor or the capacitor has failed or there is an internal short. Flash units don't do well sitting for long periods without use.
If you take it apart, just be very careful not to get shocked from the capacitor. I've been zapped taking apart lesser flasher unit.
11-24-2023, 05:35 AM   #3
Lowell Goudge's Avatar
It may be the capacitor itself has failed. Electrolytic capacitors “form down” if there is not voltage applied,
This is why it takes so long to charge a flash that has not been used for a while, until the oxide layer rebuilds itself with voltage applied the leakage current stops it from charging fully. In the extreme it results in a short circuit.
11-25-2023, 06:14 AM   #4
Thanks for the feedback guys. I'm guessing the capacitor (and thyristor) is inside the swivel head unit since I don't see it in the main body; haven't yet worked out how to get inside the swivel head unit, unless I have to have the whole unit in pieces. The most obvious screws don't enable dis-assembly of the head.
af400ftz, batteries, camera, failure, pentax help, photography, troubleshooting
The dreaded SDM failure topic - Nikon AF motor failure perspective beholder3 Pentax SLR Lens Discussion 21 07-19-2018 10:02 PM
For Sale - Sold: Pentax AF400FTZ flash with original pouch (like new) cheekygeek Sold Items 2 07-05-2012 10:58 AM
AF400FTZ auto-focus assist on modern cameras sawtooth235 Flashes, Lighting, and Studio 2 08-14-2011 05:38 AM
For Sale - Sold: Pentax AF400FTZ superbass Sold Items 5 01-21-2010 03:46 PM
AF280T vs AF400FTZ axl Pentax Camera and Field Accessories 20 03-25-2009 01:22 PM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
