11-21-2023, 01:10 PM   #1
Playback mode
Hi. I have a used KS2. I've noticed ever since I bought it that using the back dial to zoom in on playback mode often closes the review and brings the camera back to shooting mode. Sometimes, I've wondered if I accidentally touch a button. However, I'm pretty sure that this has happened when I've been extra careful not to touch anything other than the back dial. Any thoughts? Thanks, Marc.
11-21-2023, 01:52 PM   #2
Usually I touch the shutter button which immediately drops me out of playback mode
Regards
Chris
11-21-2023, 02:45 PM   #3
Des
Des's Avatar
I think it's a fault. I have zoomed in and back out when in playback mode countless times without a problem. Can also move the magnified area with the buttons on the 4-way controller. Shutter button half-press or pressing the playback button cancels playback - if it does it when you are not touching those but just the rear dial, there is something wrong. Could be a bit of dirt in the rear dial perhaps? If it's not malfunctioning in any other way, it's probably not worth sending for repair.
11-21-2023, 07:16 PM   #4
Thanks to both of you. I'll have to make closer observations.
11-22-2023, 08:26 AM - 1 Like   #5
ehrwien's Avatar
Are you sure this happens in "regular" playback mode and not in the "review mode" or whatever it is called? The one where it shows the latest picture taken for a specified amount of time? You can zoom into the picture in this mode, but I think it will return to regular shooting mode after a few seconds when you're zoomed out again?
11-22-2023, 01:29 PM   #6
Not a Number's Avatar
QuoteOriginally posted by ehrwien Quote
As I recall this is the case during instant preview mode. I'm too lazy to walk to the other room the get my camera to check
11-22-2023, 09:16 PM   #7
Much appreciated.. I'm away right now but will check when I get home.
camera, mode, pentax help, photography, playback, touch, troubleshooting
Blank playback in Manual mode - K 70 davea Pentax K-70 & KF 5 02-23-2022 02:55 PM
"One press solution" for histogram in playback mode? ukhozi Pentax K-1 & K-1 II 6 07-02-2016 09:17 AM
Brand new K-3 locks up during picture playback mode wabibito Troubleshooting and Beginner Help 11 11-04-2015 09:19 AM
why does K-5 II playback mode image expand hjoseph7 Troubleshooting and Beginner Help 4 08-04-2014 12:29 AM
Playback mode - "jumping" picture when using the rear dial. jpzk Troubleshooting and Beginner Help 8 10-22-2012 05:38 PM
All times are GMT -7. The time now is 01:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
