12-12-2023, 11:05 PM   #1
Pentax K-3 and Phoenix 50mm F1.9 issues
Hello!
I wanted to start using my Phoenix 50mm F1.9 that I got today with my phoenix P1 on my K-3. I put the lens on and it the aperture isn't changing at all.
It changes just fine on the P1, just not sure what's going on here.
I've dug through the forums and I've found a few things. All of my other manual lenses work just fine on my K-3 aperture and all.
Does the lens need to have a metal back? I saw something about needing the back of camera to short to recognize that a lens is attached. I've changed the setting under C4 #27 no success, any suggestions?
Thanks all
12-12-2023, 11:57 PM   #2
Not a Number's Avatar
The photos of the K-mount I've seen show a black coated mount on the lens. For now try placing a small piece of aluminum foil over the contacts and mount the lens taking care none of the foil falls into the camera. See if this solves the problem. If it does, you'll need to remove some of the coating over where the "data" pin would be.
https://radojuva.com/en/2013/01/obzor-phoenix-50-mm-1-9-for-pentax/
Note: the K10D doesn't need to make electrical contact like later bodies do for MF lenses.
12-13-2023, 01:15 AM   #3
pschlute's Avatar
QuoteOriginally posted by Bright_Star_Astro Quote
If the lens is the one in the link above, that does not have an "A" setting on the aperture ring, the camera must be used in M or B or X-sync exposure mode for the aperture to stop down. In any other mode it will default to Av and shoot wide open only.
12-13-2023, 01:25 AM - 1 Like   #4
Review Phoenix 50mm 1: 1.9. Test Phoenix 50 1.9. | Happy
The foil trick worked!
When scraping off the coating, how much should I expect to take off? Should I be seeing bare metal?
Thanks!
12-13-2023, 01:27 AM - 1 Like   #5
Yeah I was using it in M mode the whole time, but it still wasn't working. Gotta get this coating figured out...
12-13-2023, 02:12 AM   #6
Thanks!
You could try using metal tape. There are various things that would work. An actual aluminum tape is made for HVAC work. There is copper tape used in stained glass work. There are likely some other uses and sources.
Using tape would allow you to avoid scraping the finish off. The amount needed it just enough to allow the pin to short to the mount ring on the camera body
12-13-2023, 02:34 AM   #7
Metal foil tape is a viable alternative as long as it isn't to thick. Arts and crafts, auto supply, hardware stores all have varieties of adhesive foils. It will eventually wear off but just replace as needed.
12-13-2023, 03:04 AM   #8
I did something awfully jank lol, but I think it'll work for now. I honestly just need to get a metal backed 50mm at one point, it's pretty fun to shoot with just screwing around!
I took an soda can and cut it to size by removing the lens mount and shaving it as needed. Looks good and good enough™! Definitely going to keep it on the camera for now.
Thanks for the help!
12-13-2023, 05:42 AM   #9
Lowell Goudge's Avatar
I prefer removing the paint to bare metal. All other approaches will potentially leave metal slivers that wear offf , or brake off and get into the mirror box. Thicker materials will either put stress on the lens mount and also tilt the plane of focus for the lens slightly.
I had to do the same with my extension tubes for macro.
50mm, aperture, camera, f1.9, k-3, k-3 and phoenix, lens, p1, pentax help, pentax k-3, phoenix, phoenix 50mm f1.9, photography, troubleshooting
HD Pentax-FA 50mm F1.4 and SMC Pentax-FA 50mm F1.4 Classic devouges Pentax SLR Lens Discussion 25 11-27-2023 12:53 PM
For Sale - Sold: Bower 85mm F1.4, Pentax F 50mm F1.7, M 50mm F1.4, Tokina 500mm F8, Pentax 1.7x TC NoCo Pentaxian Sold Items 2 11-26-2019 05:16 PM
[Asking]SMC Pentax K 50mm f1/4 VS Pentax-M 50mm f1.4 VS Pentax-M 50mm f1.7 ? liemjerry Pentax SLR Lens Discussion 24 07-08-2015 04:23 PM
For Sale - Sold: Pentax DA 18-55, A 50mm f1.7, Phoenix 100mm Macro (1:2 and 1:1), Vivitar Telec soalle Sold Items 20 06-16-2009 12:30 AM
All times are GMT -7. The time now is 01:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
