04-02-2024, 09:57 AM   #1
MZ-50 problem
I recently acquired a MZ-50 which looks in OK condition, but has not been used for some years. No details appear in the viewfinder when the button is depressed half-way, but all appear momentarily when it is fully depressed. Any suggestions, please?
04-02-2024, 10:06 AM   #2
pschlute's Avatar
QuoteOriginally posted by corkcityfcpoolie Quote
There is a problem with the mirror-lift mechanism. You should be able to see through the viewfinder. I would suggest returning the camera for a refund
04-05-2024, 01:02 AM   #3
The so-called MZ-curse (except the MZ60!)
There are two typical symptoms possible if the mirror-lift mechanism is damaged (It is the plastic gear-wheel which either crumbled or is partly broken!):
1. Visible, the mirror is up instead of down
2. Not visible, the mirror sits in it's correct down position. But (switched on, film loaded etc) when one presses the shutter-release-button, there is no action but just a strange sound:
I both cases, quite hard work to repair but it is possible. The motor isn't available anymore but the motor of the MZ60 has a metal gear-wheel, so a used MZ60 might be the alternative. The MZ5n, the MZ7 and more so the MZ6 are better than the MZ50 but have the same problem.
The Z-series might be an option if size doesn't matter.
Repair:
https://everythingvintage.uk/vintage-camera/mirror-return-motor-pentax-mz-5n/
04-05-2024, 04:11 AM   #4
Jonathan Mac's Avatar
The cog in the MZ-60 is metal? AFAIK, feature-wise the MZ-60 is the worst film camera Pentax ever made and won't even work with manual focus lenses, so I've always avoided them. Not that I don't avoid MZ cameras in general due to the cog breakage, but particularly the 60.
04-05-2024, 06:49 AM   #5
Thank you all for the info. I must have been lucky with my other camera, the MZ-M, which has not given me any trouble in 20 years. I'll probably change to the Z series.
04-05-2024, 11:00 AM   #6
QuoteOriginally posted by Jonathan Mac Quote
And because the MZ60 is so bad, one can find it cheap if in need for the mirror-up motor!
That's why I mentioned it, I did the repair once myself... it is long time ago and I don't want to repeat it though, quite some work.
So if one is willing to take on this job, one can repair the better MZ series including the MZ-S up to serialnumber 5xxxxxx when it got the the same motor as the MZ60.
appear, camera, mz-50, pentax help, photography, troubleshooting
Pentax MZ-50 or MZ-7 ? happyprince Film SLRs and Compact Film Cameras 3 05-12-2013 05:59 PM
The difference between MZ-5, MZ-7 and MZ-10? Raffwal Film SLRs and Compact Film Cameras 7 02-11-2012 05:03 PM
Wanted - Acquired: any of Pentax MZ-S, Z-1P, Z-1,MZ-3, MZ-5N, MZ-5, MZ-6 tianyawoya Sold Items 1 07-10-2010 08:13 AM
Hands-On Comparison MZ-5n vs MZ-L(6) vs MZ-S k100d Film SLRs and Compact Film Cameras 37 02-01-2009 11:25 PM
All times are GMT -7. The time now is 07:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
