01-16-2009, 03:16 AM   #1
Battery compartment issue
So I have been in the cold north China for my vacation and due to the thin air over there, I now can't open the battery compartment anymore since I am back in warm ol' Europe . It seems like it is stuck at a vacuum, it opens just about half a mm when I pull the lever.
I don't want to pull the plastic lever so hard that it would break, anybody got any tips?
01-17-2009, 08:05 PM   #2
Hannican's Avatar
I just tried the battery compartment on my K10d and it does not open AT ALL when I flip the little plastic lever. I HAVE to pull on the lever to get it open...
I would pull it to get it open, just be gentle!
01-17-2009, 08:41 PM   #3
ftpaddict's Avatar
Please remember that questions are not to be posted in the Knowledgebase.
A moderator should be moving this thread shortly.
Correct me if I'm wrong, but.. the amount of air doesn't directly impact atmosphere pressure. Yank that thing out, you should be just fine.
But if something does break, it's Hannican's fault because he was the one to suggest it first!
01-18-2009, 03:08 PM   #4
Yeah I've gotten it open by now, I have to open it by sticking a fork under the lever. Who designed this I am thinking of just breaking that small lid off with some pliers, anyone else tried this?
By the way, I am quite new, I didn't see a troubleshooting forum so I thought I had to post it here.
01-18-2009, 04:55 PM   #5
Lens Buying Addict
monochrome's Avatar
QuoteOriginally posted by Hannican Quote
My K10D came that way - if there is a spring it doesn't flip the cover open.
01-19-2009, 12:23 AM   #6
The door doesn't pop open like the SD card door does. You have to turn and pull the little pop-up handle.
Those little flip and turn knobs adds some "photographic feel" to the camera seperating it from other cameras with flimsy little doors.
01-22-2009, 08:36 AM   #7
QuoteOriginally posted by sebberry Quote
It's just that I can't open it by hand, I have to wringe it open with a fork or something, which feels quite uncomfortable since those flip and turn knobs are made from plastic.
01-31-2009, 07:27 AM   #8
Ben_Edict's Avatar
QuoteOriginally posted by john_ven24 Quote
Fold out the metall lever, turn it, pull forward the whole cover with the lver and then fold it away from the camera body.
There can't be a vacuum, if you already opened the battery compartment 1/2 a mm. And there can't be a vacuum at all, as the K10 may be sealed but it is not airtight. I had the cameras with me in China, too and I guess, you just have to give it some more tries, until you feel safe, handling the door mechanism. It is a bit awkward.
Ben
01-31-2009, 07:41 AM   #9
I had the same problem with my K10D (K20D is OK). I took a pair of med. sized pliers that I inserted in the opening and applied some outward pressure (very gently) to widen up the opening a little bit. It solved my problem, but left a little mark inside the opening.
battery, battery compartment, camera, compartment, lever, pentax help, photography
istD battery compartment problem Vranx Pentax DSLR Discussion 11 08-01-2013 12:25 PM
Battery issue with K-x switters Pentax DSLR Discussion 15 02-26-2010 09:06 AM
Loose flash battery compartment door (AF-280T) iht Troubleshooting and Beginner Help 5 02-01-2010 07:48 AM
Opening frozen battery compartment snofox Pentax Film SLR Discussion 11 02-28-2009 03:18 AM
problem with AF360 battery compartment Shaloot! Flashes, Lighting, and Studio 1 12-26-2008 02:14 PM
All times are GMT -7. The time now is 01:31 PM. | See also: NikonForums.com, part of our network of photo forums!
