01-17-2009, 05:30 AM   #1
Extended Bracket Mode problems
Hi,
When I go into the Menu on my K20D and pick Rec Mode the Extended Bracket Menu is off and grayed out. I can not get to this menu. I have turned the the Auto Bracket in the Custom Menu. I tried the button on the Left side of the camera to use the Bracket fuction but again nothing happens. What am I doing wrong?
Would like to try HDRI but I need this fuction to work.
Thanks
Chambers
01-19-2009, 05:46 PM   #2
Extended bracket doesn't work in RAW or RAW+. The extended bracket comes in the processing of JPEG, so it can't work with RAW. For true HDR, you need Exposure bracket, which works with either RAW or JPEG files.
bracket, camera, menu, mode, pentax help, photography
Pentax K200d - AV/TV mode problems yeatzee Pentax DSLR Discussion 17 03-12-2010 08:37 PM
K100D Auto Bracket Mode dbuffington Pentax DSLR Discussion 1 09-30-2009 06:24 AM
Having a problem with Extended Bracket KrisK10D Photographic Technique 2 06-11-2008 05:12 AM
Exposure bracket in M mode KungKrille Pentax DSLR Discussion 7 05-12-2008 02:31 PM
Need help with exposure problems and snow photography problems, urgent please respond montezuma Photographic Technique 7 02-24-2008 05:43 PM
All times are GMT -7. The time now is 07:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
