01-27-2009, 01:58 AM   #1
Luciferase's Avatar
What happens when the shutter breaks?
Hi all Pentaxian folks,
Just wondering what will happens to a camera used beyond the recommended shutter counts and it does break? Cost for repair? DYI?
Is everything else typically still good to use? Like the sensors/ AF motor/ mirror/ etc, etc.
Finally, had anybody got experience for overly using their camera to the point it all fails (and at what extremes do they fail)?
Thx Bros.
01-27-2009, 03:34 PM   #2
dont post questions in the knowledge base.
01-31-2009, 04:51 AM   #3
joele's Avatar
you can get the shutter replaced, though it may cost a few hundred dollars (my guess $400 or so), depending on the age of the camera, it may not be worthwhile!
01-31-2009, 06:06 AM   #4
I've yet to see a post about a shutter breaking. I don't think it's a real issue. The "shutter life" specs they post are a mtbf type of specification where mtbf means "mean time before failure" and I think they are conservative as a rule. I wouldn't worry about shutter life. It's much more likely that:
1 you will upgrade to a different body or
2: something else will fail
before your shutter fails.
NaCl(not an issue imho)H2O
01-31-2009, 07:22 AM   #5
Ben_Edict's Avatar
Shutter repairs are very rare, unless you are a hard working pro user. If the shutter breaks/jams or whatever there is no way around getting a professional repair. It is not too bad, by the way, shutters are meant to be replacable.
Ben
02-01-2009, 04:04 PM   #6
Just1MoreDave's Avatar
QuoteOriginally posted by Luciferase Quote
I have replaced a shutter myself with no troubles. I got a pair of ZX-M bodies on eBay. One had a good shutter and an electrical issue, and the other had a shutter that looked like someone had poked a finger into the curtains. The main problem was getting to the shutter, which is under almost everything. I decided on the best disassembly path with the broken camera and removed the working shutter. Then replacing the broken shutter was straightforward. Some soldering was necessary. The camera still works. I gave it to my dad.
Of course, by the time the shutter wears out, the resale value of the camera will aproach the cost of a replacement part, and a new camera will be far more advanced. It may not make economic sense even for a DIY repair.
camera, pentax help, photography, shutter
Sony breaks Sigma Compatibility (I think) Aegon Canon, Nikon, Sony, and Other Camera Brands 13 09-18-2010 07:25 PM
Landscape Morning Breaks Jimbo Post Your Photos! 12 02-26-2010 10:02 PM
Dawn Breaks on the Blackwater MRRiley Monthly Photo Contests 0 07-13-2009 11:05 AM
Don't update to the 1.01 firmware! It breaks autofocus jms698 Pentax DSLR Discussion 45 10-01-2008 01:22 PM
The Continuing Adventures of Technology that Breaks.. Artymous Photographic Technique 0 12-17-2006 12:08 PM
All times are GMT -7. The time now is 07:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
